bleeding brakes
mightymopar
6:43 AM
WNY St.
About the first on Nov. I was putting my 67 Coronet up for the winter and decided to put a bushing kit in the front end. Got it all done, put the car on jack stands, covered it up and then I remembered that I forgot to bleed the front brakes because I had the front lines off. What I'm wondering is, will I have to bleed the entire system or just the front? Seems to me just the front but I'll wonder about it all winter if I don't ask. Thanks, Dave
Educated and still a truck driver.
I would bleed it now to prevent water in system.
I would try to gravity bleed the fronts and now flush the system.Are the lines still off,or did you reinstall them in November??
When in doubt,check it out.
Bleed the entire system.
Do not pump the brake pedal all the way down to the floor--just past halfway.
You risk damaging the master cylinder when pumping all the way down to the floor.
Just need to bleed the front, if that's what was open. Front and rear are totally separate systems.
Thanks for all the answers guys, I ended up having to put a heater on the calipers as there must have a frozen slug of condensation in there. Anyway, I then gravity bled them (forgot all about that option) and they now work fine. Dave
Uhm.....if you have the tiniest thought that there was moisture in the calipers-replace them. That COULD lead to a failed caliper in the future. Always err on the side of safety.
