Al K
- 9:52 AM
- Nov 15, 2009
Kind of two(three?) questions in one thread;gotta economize where you can...
First,below are the headers I plan to install on the '64. Supposed to be Hedman's(1-3/4" o.d.);they look like their stuff. Supposed to be for 62-5 B's with a big block. OK,they look like what I've seen for that app. Are they? It's looking like I'm going to have to raise the engine,at least on the passenger side,but probably the whole mill in order to remove the old(Chrysler) manifolds. Any suggestions and tips are appreciated;this is a power steering and power brakes car as well.
Next...Would you cats recommend getting the header flanges machined flat for a better seal? There's a bit of weld material(as can be seen) that seems would prevent a good seal. Gasket suggestions are welcome as well-thanks!
Ok,third(fourth? fifth?) question: I do need to replace or remove/repair the steering box;should I remove it before I pull the old exhaust? Looks like the header install would be easier without the box in place(doh!),but then there's the steering box re-install. Would that be easier with or without the left header in place?
That's all for now;these things always turn into an adventure for me,so I see the possibility of some humorous pics-without car damage or bodily harm,I hope.
