wedge5
I added a pressure relief valve, a 2nd return spring and figured out my throttle cable.
I was worried about drilling holes into the top of the manifold. I had to use bigger mounting bolts because I didn't have a small enough tap so that was a concern. I had to buy some allen head 1/4 bolts because they had a small head on them and the mounting plate had a lip on it that needed a small head bolt to clear. In the end it turned out nice and it wasn't that hard.
I also added a 2nd return spring. I had to fab a bracket. It is nothing special. I had a piece of aluminum that came as a brace in my electric fan mounting kit. I kind of polished it up a little. It is aluminum so it is light weight. :bootyshake:
I am also in the process of replacing some of the old wires. When I got the car in 99' I thought it would look cool if all the wires under the hood were blue. I don't know what I was thinking. The only thing I can come up with is; I was new to working on cars and didn't know any better. I got my manual out and I am trying to put the right colors back on. I upgraded the gauge of the wires from what the manual says, such as if it says 18ga I used 14ga. Nothing serious but thought it would help. I also noted it in my manual. Once this is done I will move to under the dash. That amp meter and Ballist resistor has to go and the wiring is a mess. I added aftermarket gauges. When I recently looked under there I almost threw up; again my early years of not knowing any better. Oh well how else do people learn.
I had some extra Lokar throttle cable parts laying around so came up with this. I had to put notches in them so the nut held it tight. I have the Indy throttle bracket for the 440-25 and it barelly fits with the Lokar cable. It rubs on the firewall. I may have to put something on the housing to keep it from taking off the paint. I am sure I have something laying around.
