do you own any of these tools?
OG max wedge
1:20 PM
Lake balboa ca
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, denting the freshly-painted project which
you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light . Also removes fingerprints and
hard-earned calluses from fingers in about the time it takes you to say, 'Oh
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle... It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more dismal
your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads.
If nothing else is available, they can also be used to transfer intense
welding heat to the palm of your hand. They can also be used to sculpture
your wife's nose when they fall from a motorhome TV antenna!
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside the
wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after
you have installed your new brake shoes , trapping the jack handle firmly
under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut
good aluminum sheet into smaller pieces that more easily fit into the trash
can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style
paper-and-tin-foil oil cans and splashing oil on your shirt; but can also be
used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted
screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding the clip or bracket
you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used
as a kind of divining rod to locate the most expensive parts adjacent to the
object you are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on contents
such as seats, vinyl records, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts. Especially useful for
slicing hands and work clothes, but only while wearing them.
SON-OF-A-BITCH TOOL:
(A personal favorite!)
Any handy tool that you grab and throw across the garage while yelling
'SON-OF-A-BITCH!' at the top of your lungs. It is also, most often, the next
tool you will need.
I have them all too plus a neighbor that's a SOB......
:rolling::rolling::thumbsup: I have a few of those tools also. I also have a Soldering Iron, used to brand finger tips.
Both styles of screw driver are very handy at creating "tamper-proof" fasteners! But in all seriousness, a touch of valve grinding compound on the tips of them, before attacking a shady fastener, has saved my *** a few times!
I thought I saw someone looking in my garage. Next time just knock on the door and I will let you borrow any of those tools you want :)
You forgot the famous 1/2 inch hand drill, most commonly used to prevent child birth when it catches suddenly and the side handle rams you where it hurts the most lol.
This reminds me of a guy I used to work with (real name Tony),but we called Rick O'shay.Every time he cracked the shits (numerous times a day), there'd be spanners and god knows what else ricocheting around the workshop.
i guess i have a few more things to make my list complete.
I just got out of surgery yesterday and I had to stop at about the third one in fear of rippin my stitches out!!
I'm still looking for some of my "son-of-a-bitch" tools!!
Thought ya found it in the frame of a car that came back after 5 years! SORRY, couldn't help it just seen the other one in "Dropping tools" I think it was, laughing so hard cant remember. Ugh-1.gif MickeyMouse.gif
I thought of another one that I have in my tool box:
EXACTO KNIFE:
A small, sharp knife-like tool used for trimming plastic to size, as well as slicing fingertips and doing random blood tests on the hands and fingers.
And I have the scars to prove that I own one!
I believe I have almost all these tools! And the worst part is they all have been used in the practice of the examples given above! LMFAO! Sigh... Yeah Im not so good at stuff,perhaps I should quit this hobby while I have all my fingers! Buy the way my trusty S.O.B. tool has seen better days! Now if I could just remember where I threw the damn thing??
:laughing6: :laughing6: :laughing6: :laughing6: :laughing6: :laughing6:
I'm dying over here - that's some good stuff. Def. need to share with my buds.
