M/T Sportsman
Joe Mopar
7:54 AM
Danbury, Ct.
Looking at some of these for the back end of my car either 28 x 10.5 - 15 or 28 x 12.5 - 15 on a 8.5 rim.
Now the ad says Inner Tubes recommended.
Really ? Do you guys run inner tubes in your rear tires ?
Not sure what air pressure I would use, will do a burn out once in a while , but won't be putting it on the track.
If you are making decent horsepower you will be able to burn these about 100 yards at will.
I have 28x10x15's on my car, no inner tubes, run about 30 psi. I have spun my tires all the way up my 100 foot driveway.
Have you considered the M/T drag radial instead? They hook very well and drive a lot nicer on the street.
The M/T Sportsman are enroute to me already. I already have the Bias tires up front so didn't want to put radials in the back.
I'll see how these run and then next time try radials.
Hey the fun part is it sounds like a pro stock burnout anytime you want.
I had the Sportsmans and the sportsman PRO's.I will try the ET streets next,maybe thay can hook:confused2:
The ones that are coming are actually the sportmans pro, should arrive today.
Hey Hemi, Did you run them with a tire tube? Trying to get feedback. How did you like them?
Thanks, Joe
NAH,no tubes and no traction.Did squeeze 10k miles outta the pro's with a spool:tied up:
