74sundance
Hey guy's I just had my truck in for an e-test and it failed, so I brought it home and set the timing to 0 deg and it passed like a new truck and runs perfect!...The next morning I went out to start the truck and it kept trying to start and then eventually did start but would die about 3-5 seconds later..It did this over and over.I finally got it running and made it to the gas station and pumped in $30.00 of fuel just in case my gas gauge had messed up and I was empty...The truck seemed to be fine but started acting up again while driving later that day.It acted as though it was out of fuel. I had to flutter the gas pedal to keep it running or it would bog and chug and try to die.Then suddenly it was fine again....Now today it would start and die again so I had some parts kicking around and started swapping but it made no difference.... Long story short, the truck will now run but only with the timing wire unplugged (The one you unplug when setting the timing) I took it for a drive and other than the engine light and smelly exhaust it seems fine.But once I plug the computer timing wire back in it starts and dies like before.Any one care to shed some light on this?
