Finished Hemi in the 65 Plymouth Belvedere
SUPERSTOCKRACER
11:46 PM
Oblivion
Been done for a few days now. just had a chance to put up some pics of the new bullet.
This one started the easiest yet with the new 16 volt turbo staert batteery and alternator.
heres a few more. passenger side shock tower is so close to the new cast aluminum hemi valve covers.
nice new charlies oil pan
let the lurking begin.
Looks like a monster SSR!
Jeff, no idea on the power, couldnt wait to put it in the car since the season is 1/2 over already. ill figure hp numbers after making some passes.
its got a little more power than last time around.
after the season is over. im going to get the headers receramic coated.
this build took way too long to complete.
just want to see what it runs before winter sets in.
new front and rear wheels & tires too. i went shorter also.
Looks good! Love those b-bodies.
Did you invert the shock tower on the right side already or are those covers just monsters?
What one(s) are you taking to monster mopar?
Gotta love the hemi especially in an early b-body. Looks great... Bet it sounds even better.
Lookin' good, Chris. With the way it wheelie'd before, it definitely looks like you're going to need to do some adjusting if you want to keep that back bumper!!!
Looks Great. Could you offer more info on your crankshaft pulley... Great Idea with the heim joint used on the alternator adjuster...
Nice install SSR, sweet Hemi
Wow, Thats all can say.That is one sweet looking motor.Now I want one.Looks good chris.I want to see your numbers.
its a mandrel drive, set up for htd belt for the alternator and a gilmer pulley setup for the vacuum pump. you use it so you can space out different pulleys for alignment.
the alternator setup is by jones. its a motorplate setup with adjustable heim ends. very trick imo and easy to adjust.
just swapped out the afcos to strange double adjustables today.
the knob on the afcos interferred with the massive idby cast valve covers. the strange worked out great as both extention and compression knobs are on the bottom.
Mark, i got the extention set very stiff for 1st pass. then will go softer each pass till i get it where i want for maximum 60 foots.
no ironside, never inverted it, i should have done it last winter while i was waiting for the motor to come back. this winter ill do it.
these indy covers are thick as hell. there is like no room compared to my old direct connection chrome ones.
Hey!! Where is the new black fuel lines? Did you not order it yet? TORK
i got them. they are on my dining room table. in time tork,in time!
next pics will have them on. just for you bud.:laughing1:
