Rb header question
NOSTRT980
8:09 PM
Pa.
IS THERE ANYONE ELSE OUT THERE MAKING B BODY CAR HEADERS FOR THE RAISED PORT HEADS BESIDE TTI? I USE THE TTI HEADER NOW BUT THINK THEY ARE TO CLOSE THE THE TRANS. AND COME ONLY WITH A HEADER FLANGE AT THE END. WENT TO PUT ON EXTENTIONS BUT THEY HIT THE TRANS CROSSMEMBER. :angry1: :eek:
I run Hooker headers and had same issue with the collector extentions. TTI has adapters to add an exhaust system to each specific header brand. Go to their website. Then order the adapters- they will straighten out the exhaust coming rearward and miss the crossmember. Get some 3 inch exhaust pipe- start with 18 inches, use a band clamp and then tune the extentions to the length you need.
As far as the TTI headers I haven't seen any non custom made headers for raised ports.
My exhaust had to have a turn right away that runs in towards the humps in the trans cross member then straighten back out running along the driveshaft.
Also, the 3-bolt flange being perminately welded in position places it so it almost touches the torsion bars.:eusa_doh:
I think I can get short turn downs in when I take it to the track for open headers, and keep the exhaust from blasting my floor boards!
