Help needed please. Anyone else running..
ramairthree
8:59 PM
USA
a small block with an edelbrock and 904?
Pictures of your kick down linkage,
both how it is at the carb, and how the throttle rod connects to the tranny lever needed please.
I have my throttle cable hooked up and adjusted good.
I need to get the throttle rod hooked up right and the spring.
My throttle rod reaches the tranny lever.
But is set to come down vertically into the lever.
My manual shows it coming in horizontal to the lever.
I also could use part numbers or source for the connection, pre load spring, etc.
Thank you for any information.
The spring can be had at any auto parts store and I will look at mine when I get home and let you know how the kickdown rod connects. This I have an aftermarket edelbrock carb and weiand intake.
You need the long kick down stud at the carb linkage.
I'm running a 360 magnum engine to a 904 tranny.
Couldn't use the kickdown lever or throttle cable mount.
I have a BPE bracket that mounts to the carb, that holds the TV cable going to the tranny. It works flawlessly.
Good luck!
Oh.. Here's the link to get all the parts.
http://www.bouchillonperformance.com/BPEtkdcInstructionsNEW.asp
Best investment. Ditch all the rods and linkage and get a bPe kit. Also, available on Mancini Racing, complete setups.
I am getting there little by little
got the throttle linakage set up except for need the long bolt
got a clip coming for the throttle rod to trans lever
Not the same set up as you have but here is a pic of the kick down. with that same bracket you have.
Here is the setup i have, same engine/trans but without the rods, i found this to work great..
