magnum 500 wheels wanted
684door
pa
Looking for magnum 500 wheels 15 inch bolt pattern 5x 4 1/2 with back spaceing 4 .5 anybody got any they are not useing please let me know
magnums
good luck
a guy sells the complete setup ,center caps,lugs, at carlisle $700.00
im buying a set this year.
You need to be asking for repos in that size because FORD had these wheels back in the day in 15" and MOPAR did not.
If you buy a set of FORD 15" they will not seat on your car because the register hole (big center hole) is smaller even though the bolt pattern is the same.
I have some Ford Magnum 14x7's and they fit my 66 Coronet just fine.
Ford steel wheels, on the other hand, do not, because of the issue you describe.
The center caps for the Ford Magnums do not clear the wheel bearing dust cap, however.
You will need Mopar/generic style
Does it look like someone ground the perimeter of the register hole? They will fit if that is done.
I know they didnt come with 15 inch origanal, im looking for 15 inch, i know you can buy these brand new, wheel vintages sells them, just checking to see if any one had any 15 inch, they were not going to use, other wise i will drive to summitt racing and buy new, they have them,
There's no register hole on the back of the Magnums I've seen, just open area between the triangular "ribs". The studs and nuts locate the wheel.
I have a set that I am trying to sell. I think they are from the seventies. They are 15" Magnum 500 and I had them on my 1969 Coronet R/T. Here is a thread and pictures of the wheels:
http://www.forbbodiesonly.com/moparforum/showthread.php?t=20147
PM me if you want me additional information, but I had 245 front and 265 rear tires on them without any problems.
