64SF
Any pluses or minuses to motorhome engines vs car? Thanks.
I have personally sonic tested enough 440 blocks to know the Mopar engine book is wrong! Others have come to the same conclusion.
http://www.arengineering.com/articles.sonicbig.html
Well, if I search it, it works.
Chevy engines have nickel in them??The nickel content and cylinder wall thickness is a myth...A 440 block is a 440 block...The nickel thing is chebby crap..
Petty Blue 67 gTx
That's the way it was 'supposed' to be but it never happened.If you check into the Mopar Engine manual, Chrysler states the blocks from 1974-1978 are weaker in comparison to the earlier "RB" blocks (They state that the maximum overbore of a post 1973 block is .030, in comparison to the pre 1974 blocks being capable of .060 overbore). We have a 1973 Block, with 231 "motorhome" heads. It came with "six pack" rods and a steel crank (wrecked police car). In 1974 Chrysler started installing cast cranks in all their "RB" engines. Prior to 1974, starting in 1971 Chrysler installed cast cranks in the 383-2BBL and 400-2BBL. This is information straight from the Mopar Performance Engine Manual, and dates back to the early direct connection days. I would try and stick with a pre-1974 motor home engine for the quality assurance and also a steel crank. In relation to your post, the motorhome heads have improved water passages so the engine will run much cooler in traffic, if you plan on building a street cruiser. Better cooling is always an advantage.
If you plan on boring to .060 over, sonic testing is always a good idea and that's with any engine. Core shift is the main problem and not thin wall blocks. On the hour glass blocks or sometimes called the figure 8 water passages, these are a good thing but the gaskets still have a small slot. Some enlarge the slots in the gaskets and some don't. I think the jury is still out on doing that? And I've found regular LY rods in cop car 440's and motor home 440's....that part is a crap shoot.so it seems that it is really a crap shoot, as stated before a 440 block is a 440 block. the only difference is how good each individual casting is. what about the "hourglass" block's? is that part of the enhanced cooling passages, I have heard this block referred to as a six pack block, this makes sense as all the ones that I have seen have the six pack rods as well as the steel crank. Perhaps that was mopars way of using up the inventory, since the six pack ceased to be produced in 1972 they had x amount of blocks, cranks rods ect. just a thought:toothy10:
I have a motorhome 440 dated 6/7/1974 it is a steel crank sixpack rod factory double roller timing set with the 902 heads, so does that mean that I have a thin wall block or is the mopar engine book misleading?
Motorhome engines usually have very low mileage on them and most of those were highway miles. I recently helped a friend replace the heads on his 70-something Winnebago (440) and I couldn't believe how nice the cylinder walls looked, nice crosshatch, no ridge.
Things were printed as how it was supposed to be but what actually happened in the foundry and in the machine shop was a different story. Remember, Chrysler was a fairly small company. Even tho they were part of the 'Big 3' they were a very small part. When you compare ChryCo to GM and Ford, they were David and GM and Ford was Goliath and GM was a good deal larger than Ford even. Chrysler did what they needed to do keep the money rolling in and didn't have all the corporate red tape that GM had to deal with when operating on a day to day basis so they rocked along and didn't make cost cutting changes so long as the money was still coming in but as time went on things got tighter and they still didn't change things much. Things were getting harder for them in the early to mid 70's and by 1980, they were getting the gooberment backed loans.The issue is like others have posted previously before. Regardless of Chrysler's direction on producing the production short block assemblies, the actual results varied. The Industrial engines (Motor home and Law Enforcement) are obviously a mystery to most, on production standards but Chrysler would not state the information in the Engine Manual if it did not hold partial truth.
I would choose an earlier build date (pre-1974) to have better odds of receiving more sought after internals.
Don't know why the 66 blocks were ragged on by them. Same thing happened to the 8 3/4 with the 489 case gears being the strongest. Someone at some rag looked at the tapered pinion and said "wow, this must be the strongest of them all." Now it's gospel everywhere but how many 41 case pinions have seen break?I have not heard of the "ovaling" of the bores but could see it if the engine had A LOT of hard mile's of heavy towing, the engine that I have, not sure of what it was, as the motorhome was stripped down to the frame but the odo showed 48k on it, amazing cylinders, only problem was the rings were stuck in the pistons( it sat for twenty years). lots of good information here but it seems the best thing to do is to get any block sonic checked.there seems to be a lot of very good reasoning behind all the different claims but with no real solid facts. I read recently that you want to completely avoid the 66 440's! this was in mopar action, why?? I could understand if it was a first year block design but the RB had been around for some time at that point, why would MOPAR action state that? I found a 66 440 out of an imperial but now I am not sure I should pick it up. what gives?
