Early weiand 2x4 install
MoparMikey
10:11 PM
SoCal
I have an early 2x4 Weiand intake that I may install on my 1965 383. It's a little different then most Mopar intakes in that it doesn't use a valley pan. The intake is like a Chevy. I'm assuming I can seal the end rails with RTV, do I use single intake gasket or just check what it takes to fit between the heads properly. Anyone install this type of intake before?
you could use papers at the head surface and rtv on the end rails. i know a guy who is using one of those intakes. they're not very good from a performance point of view. they mimic the old flat single plane cast iron intake.
What are "papers"? Do you mean the gaskets?
Not looking for performance, this is for 1965-66 "looks". Yes they do "mimic" the 1959/60 cast iron but even that intake used a valley pan.
I would use a 383 cross ram but most have been too expensive.
dont use the valley pan if all you want is looks.the pan only seals the oil in in other intakes,and keeps it off of the bottom of the intake for a cooler air charge(more power).just use paper gaskets at the heads,and a good quality rtv on the end seals.
felpro makes some paper strips that fit between the head and intake.
The intake is designed to not use one as it appears. Unless it was designed for one to fit but I doubt it. It isn't like the Mopar intake which requires a pan, the mani is solid fron end to end, like a Chevy intake.
ya,i have seen them many times.only time to run a valley pan is to seal oil from leaking,or to keep off the bottom of the intake is all i was saying.if you dont care about performance,dont try to find a pan that fits.just run the felpro intake gaskets as mentioned above.
You can set it on the engine without any gaskets and see how it lines up. Then decide. This is a cool intake and has collector value and should run fine on a stock engine.
