dryheat
The restoration on my 64 Polara 2dr Hdtp has officially begun.
One area of concern is the cowl. It appears to be packed with leaves and other miscellaneous debris. Upon closer examination the only accessible spot that I see to clean it out is behind the front fenders.
Is it safe to assume that I need to pull the fenders off to gain adequate access for cleaning or is there some other trick/method I haven’t thought of.
Also … there is “some” rust in the lower cowl area… not a significant amount but it will still require some attention. How would I approach repairing this or should I just let the professionals at the body shop handle it.
Thanks …
Thanks …
