john.thompson068
Today I drove the car and then came back to the garage to adjust the idle speed. While the car was sitting there idling waiting for me to finish hooking up the timing light, remove the air cleaner, adjust the idle and idle for a while in drive, the engine temp crept up to 230*. Afterward I turned the car off. Later I went to restart the car while the temp was still at 230* and the NAPA brand mini starter would barely crank. I retarded the timing from 13* to less and less timing, I hooked up my car battery with cables without the other car running, I tried it with the other car running, I removed the coil wire, and still the starter barely spins the motor. What is wrong with my starter and what should I do about this? There is no point to having a car that cannot start when it gets hot. And it already has a 20x 18 aluminum radiator, 18" MP Viscous fan, and radiator shroud. It runs between 160-180 when cruising around, but after cruising and then idling on a hot day temperatures easily go up to 210*-220* when sitting in traffic. The motor is your basic 550 hp pump gas 440 combo with Hooker headers.
