Rusty Fender Tag???
detmatt1
6:37 PM
Detroit Metro Area
I know I'm not the first to discover this but it is a very kool find. Anyone know what the little paper tag is sticking out from under the upper left side, on right in the upside down shot. Spent the day cleaning and dismantling, this car will be a big project but a worth while one.
Don't know .But you got a lot of work.Where are you it in the detroit area.
Thats going to be a fun project and the nice thing is. You can replace everything on it with Good Mark mopar approved parts. In fact I'd use the firewall, and radiator core support to build a new Challenger around.
It's probably some kind of "repair" tag
I had a response about the small tag that was under the fender tag over on FEBO. Was told that another tag or thin metal strip was attached and was punched with a different shaped hole as it copleted stages of assembly and then was removed or snipped off at the end. Even backed it up with some pics of these tags still attached or found loose.
hey Matt, did you ever live in Ocala Fl?
Never lived in Ocala, don't even think I've been there even though I have been to FL many times. My Road Runner, however, spent some of its' life in the Jacksonville area on the local drag strip. Do you recognize the "JUNKYARD DOG" or what it looked like after someone had painted over it in a dark blue?, see my galleries if you haven't already. You got me curious, let me know why you ask.
Thanks, Matt
my sis had a friend that was into olds cars that lived here and moved somewhere around the Detroit area, his name matt also.. i will check out your photos though, thanks for the offer!
