Hood Latch Rod
moparbob
11:13 PM
South Carolina
Hey guys, need some help. I am trying to locate correct pieces for my hood latch release. 1971 Satellite. It is a long rod 3/16 diameter.? And I need to know how it was orginally attached to latch and body. I am using a homemade rig right now and it looks homemade. :black_eye:
Even if someone could take pics of their set up. I could use the info to improve my set up.
Yes...That really does help. I would like to find the original style rod. Have not had much luck around this area. Actually my home made one is not to far off. I have the grab hook turned the other way and a piece of vacuum hose over it to protect fingers. I like your solution for stability at the bottom. Wonder what the bend in the middle is for? Thank you for your help.
Not an air grabber Buck, just blacked out. I will post a pic of the car so you can get a better look.
71
there a 73 4door and 72 two door 10 mins from me i will look for you
if there you have for free:tongueflap:
i need the inside release.one
Guess who has most of an air grabber set up he's not using? :) I have new from Stinger fiberglass: the bubble, scoop door, underhood air box, the scoop hinge, flapper door, and mounting studs. Used is the rubber seal, and the factory air cleaner. I've got about $1150 in it, if you make a trip to WV/OH/KY to pick it up, I even have an extra hood I'll throw in, all for $750. I may go to the Nats, not sure how my physical health is going to hold up, but if I do, I could take it there. There are some pictures of it on Photobucket, but I can't get it to load right now.
Car looks nice, but then, I'm kinda partial to orange lol
Buck, sorry you are not feeling well! I can't use the air gabber, but thanks for the offer.
