1970 superbird 440
tmsdist
3:15 AM
baton rouge la.
I bought a salvaged 1970 superbird burned need help checking to see if motor is numbers matching thanks tom
Tom, look at the bottom of the block on the passenger's side, kinda under the motor mount, and right above the pan rail. There should be a flat spot machined in to the block. The VIN should be stamped there. Naturally that should match the dash and fender tags
What he said, as well as the radiator core support and trunk lip under the weather stripping.
It's a 70 Coronet hood that has been cut off (at the front) and had a piece added to it
Does anyone know about a wing for sell? and does a superbird wing the same as a daytona?
Daytona and Superbird wings are different. The Daytona wing stands up straighter.
Really? I thought Ted was breakin the hoods and makin the add on piece. But it's been years since I've talked to him
