1969 dodge super bee ramcharger reproduction box, whats your oppinion? hole location
scatpack1969
iowa
i have a 69 super bee and am thinking about buying a repro ramcharger air box and air cleaner, whats the best way to go on these parts , i want a steel air cleaner with the correct lip. i have the base coronet hood and scoops for a be but i dont know exactly where to put the scoops either are there any diagrams out there for the hole locations? thanks and :HappyNewYear:
and do i need to go to a three speed windshield wiper also? thanks
:HappyNewYear:i have the hood and the scoops , that would be great 69 hemi, i wonder if i should just buy the repro ramcharger setup and look at where it seals up to the hood, i believe the holes were rectangular.
The holes are rectangular, I will get the measurements this weekend,....... If you mimic the hole location from an original hood you can't go wrong.
Yes, you will need to go with the 3 speed wiper motor to clear the air cleaner base.
You will need more than the motor. Linkage cam is different and so is the switch. Find an old C body car in a junk yard and get all of the stuff. A lot of those cars had 3 speed wipers.
I would greatly appreciate those dimensions too. I have a flat hood but need correct hole measurements and placement. THANKS!
