Motor mounts?
Bens69PlymouthSatellite
1:21 AM
IN.
Hey whats up everyone !? I have a ?? what motor mounts should I use to bolt to the K frame,I have a 69 runner clone,and a 440 engine the engine I have has motor mounts on it already,but I was curious if since I went from a 318 to a 440 if I would have to use engine swap motor mounts and if so who makes good ones,thanks alot!
I bought mine here for my 1974 Satellite/Roadrunner http://www.engine-swaps.com/
Read up on them before you buy any brand....I had to trim off 1 tab and drill (2) 9 1/6 holes,but it's easy to do.....Plus you might need a differnt oil pan to clear the K-frame.
If you want to see my mounts out of the box go to my page 3rd pic down on the page,click it to enlarge it...(Far right corner of the pic) http://www.cardomain.com/ride/3164986/5
isnt the kframe on 69 models the same for small and big block , I took a 318 out of a 69 charger and dropped a 440 in using 440 mounts
would you recommend the 440 source mounts? ive only ordered bolts through them,what would you say about the mounts?
I've never bought anything from them, so I have no opinion one way or the other. I posted that link to give you an idea of what the differences where as far as types of mounts used in different years and models, since they had photos.
Thanks alot to all of you! Im mostly just looking for a good mount for a pretty much stock 440,somthing I dont have to modify to fit correctly.
