Disc Brake question?
Small Block
8:55 PM
West Plains, Mo.
I'm doing a 64 Savoy with manual brakes and am wanting to convert to disc so the stopping will happen. What's the swap parts on this and what components do i need? Thanks
Small Block
scotts74birds, , that's the ticket . And to make it even easier......use everything from a A-body car, like discs, calipers, brackets, hoses, master cylinder, proportioning block, spindles, bearings, grease cups, and even the dust shields. And you can even get a brake line set up for the '62-'65 b-body to fit your A-body stuff...it so easy. I used everything from a '74 A-body dart. When I go to the parts store for brake parts, no matter what it is, all I have to remember is it's for a '74 Dart. You can even use your brake rod from your '64 single pot master cylinder.... I had that confirmed in a earlier post.....hope this helps. :grin::grin::grin:
Sounds like were good to go. I probably have 7 of those set ups out in the field so were on. Thanks guys. I hang mostly over on FABO but i'll be here a little more often as we've started on this 64 post project. Thanks guys.
Small Block
I'll post some up. Which thread you want em in? Dont hang here much and dont see a restoration thread. Maybe in the 62-65 section.
Small Block
Submit them in "user cp" at the top of this page. "view photos by: Small Block" will show up under your name at the left of your posts like mine and everyone can check them out. :)
There are some over on FABO in the general section in the thread "I've got to do it"
Small Block
Hey Small Block, forgot to mention that I got all my brake lines from Right Stuff, and when I needed tech , they helped me out a lot.... When you get around to installing the A-body brakes on your '62-'65 B-body, just let them know, and they have the lines already made up to fit the A-body disc brakes, on the B-body cars. Still have to tweak a little here and there but pretty simple, and alot easier than trying to fab your own......hope this helps ya out.
