65 Dodge K member swap
kdtjb
6:42 PM
In a van, down by the river,
Will a 67 V8 K member work in a 65 Dodge ? Mine has a 6 cyl. K member but I have a 67 K member. Thanks ahead, Kent.
Yes, it will move the engine back about 1 3/4 to 2 inches.
65 k member swap
hi,i have a 65 big block k member in good shape if you want to keep everything in the same place,let me know,mark
I have a 318 K member from a 63 Dodge 440 car if that will help. Real good price, too.
Blessings,
Shakota
re K member 1965
If he passes on this I would be interested if its same a 1964 style:yes:
swapping 6cyl to BBD also need a big block rad
Bear
Hello new to site. I need a big block K-Member for a 1964 dodge 440 2 dr post car.
I can be reached a 717-342-2661
I'm going to wait for permission on this because I don't want to hijack this thread but I have some questions about this K-member business.
Well, ask away!!!!
I've got a '65 Satellite 318 car and I want to install a 440. Do I need a big block K member or just one of these install kits I've been hearing about? What would I use for the trans crossmember?
Call Shumacher, they will have what aya need....Shumacher Creative Servies or engine-swaps.com. Hope this helps.
62-65 v8 K Memeber
Looking for a 62-65 B body V8 K member.
All the '65 V8 K members are the same as are all the automatic trans crossmembers. Just get the right mounts and engine brackets for any '62-'65 big block and go.
And create a whole bunch of other headaches in the process. Do yourself a huge favor and take one of the following guys up on his offer. DAMHIK
BTW - There are no small block/big block K frames, just 6 cyl/8 cyl. The mounting brackets make the difference and yes, Schumacher's got 'em.
Blessings,
Shakota
I also have several 62-65 V8 kmembers. PM me if you'd like. Located in Iowa
63-65 K-frame
We have a very nice used one....... that was removed from 64 Polara
with a poly 318. K-frame's are the same Smallblock and Bigblock. PM if interested.
