20" srt challenger wheels on 1965 belevedere
mrbe
New Member
6:26 AM
virginia
my question is, will they fit without frame or suspension chages/alterations
The bolt pattern is very very close, you can do it, make sure you tighten 'em down good, and you should be ok,
The hub/center of the wheel is a hair to small and will not fit over our rotors with out some work, a custom bearing dust cap will need to be made because the stock one will be in the way of the wheels center cap.Been there and done it :)
????? The positve off set on the late model wheels will push the rim/tire WELL into the well and most likely interfere with the brakes. If you got the time and money you can do just about anything but this will be no bolt on. In the link provided by Donny, the wheels are by Boyd and I will certainly bet they have the proper off set and back spacing. IMO
Mine clear the breaks and every thing else fine.Like I said the Cap is the only real problem.
Donny didn't post a wheel link? I did tho, it was just to show the tire size they used.
Nah, didn't have a link to post! Just talking experience here, took 'em off my wife's Charger (18s) and put 'em on my GTX as an 'experiment'.
i have thr srt8 wheel top left picture 20" and also did some mock up fitting on the rear and will have to add at least a 2" adapter to clear everything , but the front i'll have to figure out how i can get the adater to fit over the bearing and dust cover.....might look into having the back of the adapter machined.....will still need to use at least a 2" adapter to allow the wheel to clear upper control are while turning
no pics just yet, but car is flat black,sits stock and yea its bad to the bone , just hope i can get everything to lock in
Wow 2" is a lot..My rears bolt rite up no problem.....Post some pic's when you can, I'm sure lot's of people will follow this one :)
