who has the best front windscreen gaskets
dart6
8:22 AM
Auckland
Hi
This is for my 70 RR also what is the best way to remove the screen
thx
new gasket I always used softseal, for removal I have used Eastwood.
if you want to save yourself money, All you really need is a razorblade and piano wire
Thanks for that
Are they typically hard to remove, not familiar with eastwood
thx
I am 50% on removing.
Broke one, got one.
Don't rush. If you get frustrated, take a break.
Can involve a good deal of time in an uncomfortable position.
I used a razor balde and guitar low E string.
Thanks for that
thx
Eastwood is a restoration supply website. i think we was referring to using an eastwood product for the removal or the seal. Not sure what he was talking about and I buy a lot of stuff from Eastwood. :christmas_presents:
Randy
has anyone tried a gasket made by precision. I've heard that softseal are bulky and ill fitting or is that not the case.
Even better is it possible to get a nos one
thx
Softseal is supposed to be a good seal. When you reinstall keep in mind you will need to use sealer on the bottom edge especially in the corners. For removal use a razor to remove all of the seal that covers the glass and then work a wire through and then use two people to cut the seal with wire with a piece od wood on each end of the wire for grip. Take your time and don't force it and you won't break it.
