- 9:29 AM
- Apr 13, 2012
- Granite Bay CA
I have had a ongoing problem with the brakes in the Charger. I have tried several master cylinders, combination valves and the brakes still suck.
Here are the stats: 1970 Charger. Front has 12" Cordoba rotors, 2.60" piston calipers spec'd for a 73-75 A body, Raybestos pads. Rear is 10.7" rotors with 1.5" piston calipers (Dr Diff kit). I am currently using an aluminum 15/16" non power master cylinder, also from Dr Diff. Below the master is a drum/drum combo valve.
From 2001 until February of this year, I had a power booster on the car, along with an iron master cylinder spec'd for a 73-76 disc/drum A body. The brakes were great EXCEPT at low speeds, due to the lumpy cam and low vacuum. I switched to manual to have predictable braking.
I have tried 3 different master cylinders, and this 15/16" one has the best feel so far, but the brakes are still pathetic. Yesterday I drove my brother-in-laws Duster and was blown away by how fantastic that car braked. Its all factory stuff on that car, but from different years. 11" rotors, 2.75" piston calipers from an '88 5th Avenue and 10" drums. NON power stock master cylinder spec'd for a 73-76 A body. The larger front calipers got me thinking....I bought a pair of Raybestos 2.75 calipers and started swapping them in. What if the newer, larger calipers and brake pads make no difference? Where do i go from there?
The Charger feels as follows: You press the pedal and while there is resistance, it just feels like the brakes are not responding very much. Its just like when brakes are fading: Increasingly firmer pedal but little reaction. Today was the first time I got the tires to skid, and I had to really STAND on the pedal to get it. The rears skidded, but the car didn't feel like it was slowing down any faster the moment before they skidded like you'd expect. THIS is where the point of this post comes in!
What if the combination valve is a POS? Has anyone plumbed their brakes without one? My thoughts are to run a line from the M/C front reservior to a TEE, splitting off to each front wheel, THEN run a line from the M/C rear reservior, through an adjustable proportion valve, then to the rear of the car. I read in Mopar Action about this, April 2004. Has anyone else made this change? Does anyone have advice on the matter? Thanks, Greg
