sstocker31
- 12:45 PM
- Jul 11, 2011
- Edmonton, Alberta Canada
Fresh rebuild....cam lube on cam and lifters......2500 RPM right after light off, without excessive cranking (primed carb), ran for 25 min 2000-2500 RPM. 10-40 oil with two bottles of zinc lube. Engine was oil primed.
-New comp 911-16 valve springs (125 on the seat...not excessive)
-New comp 280H cam
Removed oil pan due to a leak at the main seal cap. Got that fixed and decided to look at the cam lobes while I was there. Could see some but had to move the crank to see the rest.....the last one I looked at was wiped....gently wiped, but definitly on it's way out.
I've read alot about wiped lobes, but never had one myself until this....I guess it's time to research hydraulic rollers....
-New comp 280H cam
