Hydraulic Roller Cam and Lifters-Hemi
Hemirunner
4:04 AM
Down South
Feedback: 17 / 0 / 0
Comp CRH2513B/2516B HR12 Hydraulic roller cam new in box.
.609 lift intake, .589 lift exhaust
252@.050 int, 258@.050 exhaust
112 LSA
This is a great hydraulic roller for a big crate hemi, never run the valves again:hello2:
Lifters are Comp 8921-16 hydraulic roller lifters. I stuck a rod through the side of my block before i was able to change over to this cam and lifters and new engine is going a different direction.
$650 for all plus the ride from Illernois....
Hemi Roller
Could not find this cam in Comp Cams listing. Is it a custom grind? What is the application. Seems like it may be race and not streetable......
I may be needing something milder in the 500" Cross ram street motor Im building.
Are the lifters available separately??
It's a custom hydraulic roller cam for a 500" or larger with good heads. I have another milder grind that's also NIB. It's a COMP 24-712-9 which is .574/.551 and 242/248@.050 on a 110. I'll make you the same deal on that as a package.
I've also got a wedge hyd roller cam for a 500 stroker...
Are you building a cross ram Hemi?
YES. I am building a 500" Cross Ram Hemi from a 440 + .030 and a pair of Stage V Hemi conversion heads for my 68 Barracuda.
I was going to go all out with 12 1/2's and a solid roller, but now Im thinking about loosing the hi domed pistons and going with pump gas and a hydraulic roller since it will see mostly cruise nites and few 1320 passes.
So Im in the market for pistons and cam/hyd rollers/push rods.
Any suggestions?
