63dodge440
can someone point me into the right direction on the proper linkage set up, for my 440 727 holley setup...what iam using now is a one piece that goes to the kickdown arm that has the adjustment at the tranny and a piece that bolts to the intake and has a u shape piece that pivots..has a flat sloted steel piece at the carb....if i go full kickdown and set it for full throttle when i release the everything with the adaptor for the holley, there is about a 1/4 inch space before the rod touches the kickdown arm...havent tried it went...was told it should follow the throttle arm from idel to full throttle and full kickdown in a one to one ratio....if i hook it up to follow the throttle i hit full kickdown and have no full throttle any ideas...
