696pack
Will the Edelbrock Performer RPM high-rise, dual-plane intake manifold fit under the stock hood of a 66 Charger? They make both a high rise and a low rise manifold.
I am looking for suggestion for an intake manifold and carb for my 523 stroker that I previously had a factory 6 pack set up on. I know I will likely get a lot of answers with a lot of different suggestions so please limit this to actual experience and not what you THINK or have read somewhere else without any actual personal experience.
My mechanic says an 850 or a 950 cfm is his suggestion with a dual plane manifold. He says a common mistake is too big of a carb and that a 1050 will be too much even though the car HAD a 1350 cfm six pack set up previously.
Here is the story on the engine and my intended use.
523 stroked 440. The cam is a roller with 112 degree lobe separation. Intake .022 valve lash hot .630 valve lift 284 duration Exhaust .024 .608 288, and after indexing the lift is 420/244 I and 405/252 E. The stock heads were ported and flowed. Of course it is balanced and blueprinted. For some reason the compression is not shown on the blueprint sheet, but it will run on pump premium. Factory hipo exhaust manifolds. (don’t get me started on headers or even suggest them it is not going to happen) It will have an electric fuel pump and 3/8 fuel line.
I want the car to have some street manners and am thinking of a vacuum secondary carb. I plan to drive this car daily and I will be adding A/C to the car. It will also have a Passon Performance 4 speed overdrive trans. Probably a 3.54 rear gear but I may step up to a 4.10, undecided as of yet.
