Mid Rise Lifts
1970Moparmann
12:12 PM
Chicago
Guy's been reading until my eyeballs hurt - AGAIN. I try and research prior to asking questions like this.....
Does anyone on the site have a MID RISE lift? Looking for opinions and facts about any.
Here is what I have learned so far in my research -
Bendpak MD-6XP Around $1,900 delivered.
- 6,000 capacity, "best looking" locking mechanism. I say this because it is the most beefy. I'm one that takes things to the next degree - example, I see a lot of people climb under a car with just a jack holding a car up. I'm the guy that has 4 jack stands on just the back of the car.
http://www.bendpak.com/car-lifts/specialty-lifts/MD-6XP.aspx
Revolution RMR6. Around $1,900 delivered.
-Same 6,000 capacity. Locking mechanism is more like the next one in which it has smaller increments of locking positions. Some have posted on other sites this was a main factor for low ceiling garages versus the BandPak that you have more space between "locking" positions and need to be careful to not go too high in a low ceiling garage because you have to raise it up slightly to make it go down.
http://www.revolutionlift.com/RMR6-6000-Pound-Capacity-Mid-Rise-Lift-P4.aspx
Atlas TD6MR. Around $1,300 delivered.
-Same 6,000 capacity. Same locking mechanism as the Revolution. Again, not the same as BendPak, but since the Revolution is the same, I would think the locking mechanism is rated for more then the 6,000 it claims to be safe.
http://www.gregsmithequipment.com/Atlas-TD6MR-Portable-Scissor-Lift
I've found good reviews from each option above. Looking for some feedback.
Do you want a mid rise because of height constraints? Just askin, because for about the same price as that highest one, you can get a Bend Pak two post lift.
My garage is 20 x 20 and I have to fit two cars in it. I would even consider a Maxjax, but would take up too much room.
have you seen the lift that ma snart had posted awhile back :eusa_think:
Have you checked out the Shop, Garage & Tools forum section, there is a decent thread about lifts there also...
