Steering column
68GTX4SPEED
12:44 AM
Sweden
Does a steering column from a 1968 B-body fit in a 1966 B-body?
I don't know if it would fit or not, but many of the other suspension & steering components fit 66-70 B-Bodies are interchangeable, can you measure both & compare them, I could measure &/or take pitchers of my 68 RR column if that will help, it's been modified for a Rack & Pinion from Unisteer though at the very end for a swivel joint...
I have one from a 68, its out of my GTX and a guy with a 66 Coronet need one but I dont know if it will fit.
Wish I could help, but I don't know for a fact, they will work, in a 66 Coronet
It will not work. The 66 column is narrower than anything else. You can't even use a 67 column in a 66, The dash frame is narrower.
