Help !! Sem Leather & Vinyl Repair
70RR
6:56 AM
Tampa Fl
I listed this in interiors last week and still no instructions !!:eusa_think:
I have a Tube of this from SEM # 38422 LEATHER & VINYL REPAIR COMPOUND 3oz Tube but, came with no instructions, it tells you to read the box..What box ? It looks like you just squeeze out of the tube but??
Can some one give me SEMS 38442 - 101 in how to use..:eusa_think:
Using on a Dash Pad...Thanks Rick
I have had similar issues with the lack of instructions; usually a call to Sems tech support has been very friendly and helpful.
This is a heat cure compound suitable for use on leather and vinyl. Apply thin coats and fully cure each coat before applying the next one. You will need to use a heat gun or an iron - a hair dryer won't get hot enough.
If you apply the compound too thickly, you will cure the top layer, but the bottom won't cure and you will get a failure that looks like small curd cottage cheese - although it may take some time for the failure to happen.
The compound will take a grain, and can be lightly sanded and painted.
Hope this helps.
