Flasher
1966 Hemi
8:08 PM
Orlando
Could someone please tell me where the turn signal flasher is located on a 1966 Plymouth Satellite. I just bought one and the turn signals dont work? any Ideas?? :eusa_think:
On the left side of the ash tray....there's a clip that holds it to the slide up under the dash but are you sure it's the flasher and not a ground. Do the lights come on but do not flash or not come on at all? The problem could be the switch in the column. Do the brake lights work? All of that goes through the switch in the column.....
the lights don't come on at all. the brake lights work fine. However there is a a little switch (toggle) stuck under the dash on the left side of the column that almost looks like dodge?? It plugs into the harmess when I flip that the parking lights come on and one green indicator on the dash.
Sorry to disagree, but the 66-67 flashers are to the right of the ash tray. They are really under the glove box. The origional ones are clipped to the bottom rail of the dash frame, but if replaced, the are most likely flopping about.
The toggle you speak of is the 4x flasher switch. There will be (or had been) a separate flasher. Again, after all these years, it may be "flopping" You should be able to follow the toggle harness and find the connector. Both are two prong L shaped connectors
ws27 is correct.i am currently customising the dash on my 67 and that is where mine was.reach under the dash below the glove box and it should be sitting just inside the lip.
