Stroker Billet crank
A-12.F6
10:07 PM
Minnesota
I'm selling a Bryant Racing billet crank, 4.375 stroke, knife edged, oil holes are chamferd. B/RB, was built for a 426 Hemi, 8 holes for flywheel, it's in perfect condition, journals have been turned .10/.10.
local pick up only, these cranks are custom made and run $3,000 new, asking $750.00
More pics. I can ship to states that have Spee Dee, MN, WI, IA, Il, ND, SD.
Beyer to pay shipping.
Yes, it was completely checked before the journals where turned.
The machine work was done by Crankshaft supply in Minneapolis MN.
That's a blown alcohol crank. It has no provisions to center a stock style flywheel or a converter snout. Just so you guys know what you're buying...
It's accually a blown nitro crank!!
Comes with new bearings, Speed Pro 8-7300SHA 10 rod and Federal-Mogul 4095 M 10 main.
If there is any question to the quality of the magnaflux and grinding, I will add that Crankshaft Supply is the best crankshaft shop in the upper Midwest. I have bean dealing with them for almost 30 years. Roger would have done the work on this crank and he is the best.
Can crankshaft supply weld in a stock flywheel/converter regieter and turn it down so a stock flywheel will fit and wont explode ??
You would have to call them and see if they could.
