benno440
is there a method or a tool (besides a timing light) to get you timing perfect, i may be asking a dumb question but i am a bit lost in the tming department.
also how do i work out my compression, hopefully i have given enough information.
engine 440-505" stroker 4.350 bore, 4.25 stroke
stealth heads ported 80cc closed chamber with quench surface
cometic MLS gasket 4.410 bore .40 compressed thickness
flat pistons with dual valve reliefs 27cc, block decked to have piston arrive at top of block (pretty sure its at .00", Is this feasable???) as i have not got piston in blcok yet but am pretty sure thats what the machinist said.
is there any more information i need to give to work out how to properly set my timing?
thanks in advance
thanks in advance
