- 10:39 AM
- Nov 21, 2008
- In GTXtacy Illinois
i purchased a couple new 1ohm (allegedly) ballast resistors from Summit....these... http://www.summitracing.com/parts/dcc-5206436. i've read that they will leave you stuck if they go out. :sad4:
so i get them, and then decide to ohm out the ballast resistor that's in the car now. :eusa_eh: with the car off, and the wires unhooked, i ohm it out...1.6. so im figuring its on it's way out, right? i ohm out the "new" one, 1.6 as well. WTF. so i ohm out the probes to each other... 0.3.
ok. so i figure out the wires themselves have 0.3 of resistance, right??
since they both ohm out at the same, then it seems that the two ballast resistors interchange then, no?
then i probe my coil (just for the hell of it), its stamped 12 volts on it, but with the car running (and the old ballast resistor hooked up still) it registers 8.65 volts. with the car off, it registers 6, 6.1 volts.
should the coil have only 8.65 volts going to it when it's running??
does the ballast resistor have anything to do with the coil not getting 12 volts??
im quite the noob when it comes to electricity and the like, so if y'all could explain it to me in relatively plain English, it would much appreciated. :toothy6:
