fender part...help !!
terzmo
10:31 PM
buffalo,ny
just recently bought a 67 coronet and when changing the lower door hinge, I could see right throgh to the front tire...both sides...I believe the missing part is the inner fender splash shield. Checked with AMD and they have for 68 on up. Anyone know of a source for the part and if I'm using the right terminology. thanks in avance...
I bought repro ones made out of fiberglass from a guy on ebay (winslowmspts ) I dont see them listed but if you call he may have some. They fit nice and were good quality. Cost around $190 shipped. He listed them as 66-67 charger coronet front fender shields. 66 part book has it as Shield 23-34-121 (shield, dash pnl. to fender 2570 206-7)
No those go on the bottom of the front frame rails between the K-frame mounts.
The fender shields are sheet metal. Here is a pic of some for other cars. The are contoured to the shape of the fender sooooooo you need ones from a 66-67 Coronet only. No other years or models will work.
Thanks...any 67's in there ? lol
Sherman makes a set. www.rockauto.com go under body parts for a 66 or 67 charger (for some reason they dont list them under coronet but they are the same fenders and shields). I think they are relatively inexpensive.
Jegs sells the sherman ones.
Sherman Parts 171-42R (and 171-42L) - Sherman Parts 1966-70 Dodge Charger Panels and Parts
Not sure if 66 would be the same as 70?
Not sure of the part numbers but its 66 and 67 only. They have to match the fender contours and only those years are the same. Should work for the belvedere, charger and coronet models of those same years but that's it. they are pretty cheap through rock auto and I posted a 5% discount code which usually covers shipping.
Just checked the parts book. 66-67 Coronet/Charger/ Satellite #2570206-7
Usually Dodge and Plymouth are different.
where's that code ?
jeggs shows the part for 67 through 70 when we all know the fender contours are different...but rock auto shows the same part number for 67 exclusively...plus rock is 20 bucks a side cheaper
If you go with RockAuto, be sure to utilize the discount code for them...Couple guys including kb67mopar has a thread for it in "General Discussion-Anything goes" area.
what is the discount code ??
119648778804119 is the code.
and while I agree that their body lines are not the same, this area of both fenders IS the same as well as the doors are identical.
Thanks and wow...what a code....CIA worthy
