New Car A36 Performance Axel Package?
Doubleclutch
10:04 PM
Jupiter Florida
Anyone know the spec on A36 trim code?
I assume 3.55 rear with sure grip. The car sure turns a lot of RPM for a 3.55? Runs 3300 at 60. Its a very low milage car that might have the axel tag still on it. I'll get under it soon.
73 Roadrunner with P225/70 14 tires.
Thanks Chuck
Just jack the rear of the car up. Make a mark on your tire and drive shaft. See how many times your driveshaft rotates for one wheel rotation.
Seems a bit steep for 3:55's sounds more like 4:10's. At this point, unless you know the history of a car there could have been anything done. Except for a few 318 or slant 6 cars, i havent had a car with the original motor in it. Ahhh, if only cars could talk.
A36 '72-'74 Performance Axle Package
3.55 Axle Ratio w/8.75" HD axle, Sure Grip,
Maximum Cooling Radiator w/fan shroud, (Includes
Power Steering Oil Cooler - if Power Steering is Ordered)
Available with 4-BBL Engines only, 4-speed or Auto Transmission.
N/A w/440 4-speed.
Thanks guys.
I had a true Mopar guy go over it last night. Its missing the heat shields over the headers. (Has performance headers Y21 code) the shields are a likely deletion for racing.
The package may also explain my car missing a S-77 code for power steering???
I don't follow the purpose of the shields? Why pull warm air into the air cleaner? Is this a cold start enhancement with a heat valve in the passage from the shield to the air cleaner?
Back on track for the thread --I'll report back. But the car is going into storage after a major service --I got to sell one to get back into it.
