Post your 12 second combos
65' Coronet
3675 lbs. w/driver
440-.30 over
Pistons-TRW flat tops
MP 484 Hydraulic Cam
67 915 Heads- 2.14-1.81 valves
(stock stamped steel rockers)
M1 single plane intake
850 holley DP
TTI Headers
Full 3" exhaust w/crossover and flowmasters
727 Trans. w/reverse manual valve body
9 1/2" converter-3500/3800 stall
8 3/4 rear- 4.30 posi
30" M/T Drag Radials
S/S Rear Springs w/ snubber
90/10 Front Drag Shocks
ET 12.00's @ 111 MPH "All Day On Pump Gas" -"Street Driven Regularly"
Easy high 11's with minor tweaking............
Sweet one there! Like those 65's.. they sure are aggressive impressive going down the track..
1969 Dodge Super Bee
440 bored 30 over
440sourceheads
Edelbrock RPM intake
comp cam
1 7/8 headers.
727 shift kit, and 3000 stall converter and 3:91 gears
12.71 at 109 MPH
1965 Belvedere I
69 440 .030
KB 184 9.0:1
purple 484 284
stock 906 heads stamped rockers
performer rpm 750 cfm dp
msd dist 6al
727 revrse manual vb
ATD 3500 10 inch
8 3/4 3.91 spool strange ss axles
ss springs and snubber
best et 12.47 @ 107 5500rpm shift point
Looking for info on a camshaft to get this combo into the 11s consistantly, any recomendations?
Disclaimer: this thing hasn't been down the 1/4 mile because there are no 1/4 mile tracks where I live but it has done a 7.96 @ 86.7 in the 1/8 with a 1.71 60 foot in 2500' DA which should equal a 12.45-12.55 or so.
67 Satellite, all metal, full interior, 3600 pounds.
Manual Steering, manual disc brakes
1971 440 bored .040
9.5:1 compression
Stock steel crank
Stock rods
TRW 2355 "6 Pack" pistons
Engle hydraulic single pattern cam, .534 lift, 238 @ .050
Crane 3/8" pushrods
440Source roller rockers
Unported 452s, stock valves
Edelbrock Performer RPM intake
Holley 850 DP with choke horn milled off
Carter M6903 mechanical fuel pump
3/8" metal line from tank to carb bowls
Hooker 1 and 7/8" headers with cutouts
FBO distributor and electronic ignition conversion kit
Dynamic 9.5" converter
Transgo TF2 shift kit
Stock console shifter with Shift-R-Gate modification
3.91s in 489 case with clutch-type Suregrip and crush sleeve eliminator
3400# Superstock springs with adjustable pinion snubber
Pinion angle set to 4 degrees down with shims
Rear shocks are Monroematics for a D150 pickup
Front shocks are Calvert 90/10
Front swaybar removed
Front wheels are Weld Draglites 15X3.5" with 165/80-15 radials
Back wheels are 15X7" cop wheels with 27X9" Hooiser Quicktime Pro D.O.T. bias ply
Future plans to get into high 11 range:
Weiand tunnel ram with 1850 Holleys?
4.30 gear?
440Source heads?
Subframe connectors?
Fiberglass hood and bumper?
Solid lifter cam?
Learning how to tune it?
Learning how to drive it?
My old wagon I sold in '05.
360 crate motor / 904 / 9.5 Dynamic converter / 4.56 / 12.49 @ 106 best.
Fun, low maintenence, consistent bracket car.
1965 Belvedere I
69 440 .030
KB 184 9.0:1
purple 484 284
msd dist 6al
ATD 3500 10 inch
car weighs 3730 with me in itView attachment 92923
Camshaft swap might not be your best bang for the buck in your case.... I would look at getting into a new set of heads if it were me... Getting that engine to breath will reduce your ET the most, and although a camshaft can and does make the engine breath differently, your intake and exh ports will choke the camshafts designed profile to something other than what it can already do.
There are plenty of people who have ran 11's with factory cast iron heads with port work,,, I think it's so much easier to purchase a set of Edelbrock heads and know that your options are open for the next level in performance, and cheaper in the long run too!
I agree something with the cylinder heads 1st at least a minimum of some professional bowl & port work, multi-angle performance valve job, {I agree it's probably better in the long run to buy a set of 84cc chambers or smaller to bring up the compression ratio, in an aluminum cylinder heads, there much lighter & flow much better to begin with, you be money ahead in the long run, compared to making the 906's work, but they can be ported too} a much better performance oriented style carburetor {& intake ?}, adequate sized fuel supply/pump, filter & lines, more camshaft to fit your needs weight gears converter etc. & quality adjustable rocker & shafts, w/proper length & style of push-rods, properly matching valve-train components, maybe a looser/higher rpm stall speed converter, all other thing that would help, like sub frame connectors, the battery moved to the trunk & a set of drag radials at a minimum or slicks, a set of adjustable drag shocks frt/rear, a set of Calvert/Caltracs traction suspension bars or a set of S/S springs w/adj. pinion snubber would be a good idea too, if you don't already have that stuff... taking some weight out of the car is also a great way to go faster, replace hood & bumpers with quality fiberglass peices... It's all about power to weight ratio in the long run.... Good luck & have fun
1964 Sport Fury
1974 440 .030 over
cast crank,trw forged pistons
Edelbrock heads,84cc
Hughes cam 505/515 lift 223/230 deg @ .050
full manual 727 w/2500 converter
3.91 locker
750 race demon/performer rpm intake
Hedman headers/full 3 inch exhaust
Run with full exhaust,front and rear sway bars attached
as driven on the street.
Best time 12.12 @110 ,1.76 60 ft
Furyous thats one nice 64 you have. Ron
71 Charger street car, 4150 lbs with driver and fuel.
451" stroked 400 block, 11:1 compression, B1 B/S heads, Ultradyne 251/251@ 0.050, 0.614" street roller cam, M1 intake, Holley 1,000 HP 4150 carb, Hooker 2" headers, TTI 3" "H" pipe exhaust with superflow mufflers, 3.91:1 gear, 27" M/T ET Street tires, 10" Converter (about 3,500-3,800 stall).
No hood scoop, only traction aid is a pinion snubber and extra leaf added to the stock springs.
consistent 12.50@110mph at Bandimere. Took it to MATS in Vegas and ran 11.80's @ 115 MPH without changing the tuneup.
sweet
That was the old reliable 451 engine. The new 500" stroked 400 with 12.4:1 compression, Max Wedge Victor heads, Indy intake, and Comp 264/264 @ 0.050", 0.714" cam (same carb and exhaust) makes about 100 more HP. The car has run mid/upper 11's at 120 MPH (at Bandimere), but the 60' times are not very good. I installed a spooled Strange S60 for this year, hope it helps. Also, this new combination has been unreliable because of the issues I have had breaking the rocker stands on the heads. I think I have got that problem solved
With that Combo Id'e say your leaving alot on the table somewhere! That's an awful lot of engine for the ET as you probably know.
Are you still spinning at the 1/8th mile marker? LOL! Sounds like a 10 sec ET build you have there.
My engine is a standard stroke 440 bored .030", a touch more compression, less camshaft MP 590 with 1.6:1 rockers, same heads, Victor intake, 4.10:1 8 3/4, running Mid tens...
Sounds like the man has a plan, I love them 6bbls on the street... I would suggest to get some better metering block/plates, I went with a Quickfuel Tech. tuneable for the center 350cfm carb, Promax tunable plates for the 500cfm out boards & 50cc acc. pump, slightly lighter vacuum diaphragm springs, larger squirter & staggered jetting it makes a big difference for drivability/tuneability....
thanks for the tips. I'll file away for now. I have a 440 6 BBL motor in my RR but running stock 4 BBL intake and Eddy carb. I have a 69 1/2 alum 6 bbl intake and purchased brand new 3x2 carbs, breather, lines, etc about 20 years ago but have never put this set up on any car. Some day i will!
Thanks. The car is not ideal for drag racing. It is/was my street car, is heavy over 4100 lbs, suspension setup for handling so it does not transfer weight very good. Now that the spool is installed, I may replace the Mopar 0.96" Torsen bars with some from a 318 car.
I would think it could get into the 10's at lower altitude, but the car has one other issue, no rollbar.
Yaa,,, elevation is a killer for you!
I left the 318 Torsion bars in mine, and I also installed my own CalTrac type setup late this year.... I hope they help me get a grip with the Hoosiers. I too have to install a roll bar into my car to keep from being asked to leave after the first pass! You can only do that so many times before they don't let you unload from the trailer... LOL!
