I have a 69RR without fender tag or build sheet. The sequence number is 32680 from the VIN (H9G132680). Does anyone know the build date or the vehicle order number???
Thanks in advance
Robert
Thanks in advance
Robert
Robert
I don't know if 69's are the same as 67'S, but look on the rad support on the side facing the radiator on the drivers side. It is the horizontal part of the rad support at the top of the radiator. You should be able to see a stamped number. The first three numbers like 625 (June 25) is the production date. The rest of the numbers are a random shipping order number that will not match your VIN.
Thanks. I found another RR convertible with a VIN within 100. So I believe I have narrowed it down within a day or so.
Maybe...I've seen cars with an SPD that is weeks different than cars with similar VINs.
