Isolator eliminators
YY1
6:11 AM
FL
I'm growing weary of my squishy 73 iso-comp ride.
I miss the go-cart like handling of my 70 Bee.
Who has the best value solid K frame "isolators", and rear spring iso eliminators?
Thanks much.
That ISO eliminator kit looks just like the earlier style shock plates and U bolts. I wonder if you could just use those instead and save some dough. You'd have to supply your own centering pins, but those are cheap.
You can did they have them for a 8 1/4 rear? I know my Charger had ISO Clamps when I put in a 8 3/4 rear I just changed the shock plate.But I also put new springs under mine too.
I simply would go poly. Easier SPECIALLY ON REAR spring pads... no need to change plates or anything... and stiffer
