splicer
- 10:57 AM
- Jul 24, 2011
- Plattsville, Ontario, Canada
I have a question for any of you that may have played with retarding/advancing cam timing.....
What I have is a big block stroker with 10.75 to1 compression ratio...
Cam is Cmp Cams 23-701 mechanical roller..
Lobe Seperation 110
Int Centerline 106
Duration 280/286
Lift 570/576
Cam is installed staight up at the moment.
Right now , car(3800 lbs) comes out of the hole hard with 0 to foot time of 1.60 but seems a little lazy for the rest of the run....11.42 secs. at 120
Would advancing or retarding the cam do me any good ????
Splicer
Lobe Seperation 110
Int Centerline 106
Duration 280/286
Lift 570/576
Splicer
