Al K
- 1:14 AM
- Nov 15, 2009
As I've often stated,I'm trying to do things on a tight budget. I know cheap isn't always good,but once on a while...
A couple of years ago,I picked up a set of used Venolia +.030 slugs at a very good price-with pins and Spirolox. Supposedly only used for a short time on a dyno,until something went amiss and the engine was disassembled. I checked them out at the swap,didn't see any major issues(cracks,etc.),shelled out a buck-fifty and walked. Now,I'd like the opinions of those more well-versed than myself. If you cats tell me I've got eight new ashtrays,I can live with that-but please tell me why.
The suspects:
There are some slight "scratches" on the sides-on some,but not all. Will they clean up?
Also;a couple of them had valves make contact. Nothing serious,but there are marks there. I had a magnifying glass with me,checked the pin area and underside for any cracks due to this and saw none.
Like I said;if you guys think they aren't worth the potential problems,I can accept that. Just means I'll have to come up with the $$$ for new stuff. Donations can be sent to... Since I've got the heavy 908 rods,I was hoping to cut the swinging weight with these pieces. I plan on polishing and rounding off the sharp edges to cut down on any potential hot spots,and enlarging the fire slot. The Mopar Performance book also has a diagram showing how to remove some of the dome(rounding it off),again for eliminating a possible detonation-causing area. Might consider that. I'll also be using Fel-Pro head gaskets(.039"),so that should keep the compression to a reasonable(10.5 or so) level. I will be mixing racing gas with pump Premium as well.
Gentlemen;I value your opinions, You haven't steered me wrong yet in matters of advice. As always,THANK YOU!
The suspects:
