WIW 318 poly parts
6t4polara
3:01 AM
Mi.
Parts are not mine posting for a friend who does not own a computer.
57-58 Poly 318 factory dual quad intake #1822001 F-270 cast iron.
Weiand Stealth High rise 4 bbl.intake,aluminum.
Factory two bbl.intake and carb.cast iron.
These were at one time or another on his original
1962 Plymouth Fury 318.
Also the complete 318 engine.
thanks,
The Weiand can sell between 150 and 5 hundred depending on condition and the sucker paying the price. To be honest with ya, you could have one custom made and with a higher performance ceiling for less than what the high end is on these intakes. But theres suckers that will pay the price if it is real nice.
The Factory dual quad is similar. Though price can be considerably high if perfect. I paid $200 for mine with the old paint and grease on it. The only defect was the heater tube on the passenger side. It still works, it's just not perfect. I don't care about it.
The 2bbl. intake is not really worth much since there the normal intake on the engine and by far the most common. Maybe $50
Good luck with the sales
Where does a guy get a custom made Poly intake built so cheap? I'm listening...
Your kidding right?
OK, at the risk of sou ding like a jerk.... Take a welding class and start practicing.
Local to me they do it for under $500
I don't know what the big deal is?!?!
Your kidding right?
The cost of a welding class + the cost of materials + a 'couple' attempts to get it right...and I'm easily over $500.
Are there things to that one needs to know, i.e.: dimensions/ shape/ lengths of runners?
So I would need to get my car to NY so they could make the manifold using my motor as a 'template', right?...or do they already have a pattern from yours? Is it designed for low rpm or high rpm performance?
The 'deal' gets a bit bigger for me.
My buddy Charles made an intake for his 392 Hemi out of a piece of mobile home frame, two intake flanges and some lengths of industrial radiator hose. He has less than 200 bucks in it. Google The High and Mighty. It's very similar to that intake. They are not difficult to make. Look at this kit.
http://www.ebay.com/itm/Chrysler-He...Parts_Accessories&hash=item415d9d50c1&vxp=mtr
It's not like it's CIA secrets or rocket science.
The dual quad intake go for around $300-$450 from what I've seen. (with the right buyer) -
The Weiand 7503 4bbl intake goes for big - last one I had I sold with a 1407 Edelbrock carb core for $780.00 - Paid $40 for the intake
Talk about profit margin. Sounds to me like you screwed somebody's eyeballs out.
Thanks for the responses I will pass the information on.
If your crying a out the cost of a welding class that gives you the tools to make. Save and create money, the. You shod turn in your wrenchs. Your worried about costs????
OMG! Wheel your tool box on over. You have no need for it.
There's gotta be someone talented in Md. that can do this for you.
6t4polara, my appologies for the thread getting so far off topic.
"...If your crying a out the cost of a welding class that gives you the tools to make. Save and create money, the. You shod turn in your wrenchs. Your worried about costs????
There's gotta be someone talented in Md. that can do this for you. "
rumblefish,
Wow. Good thing I have thick skin. I simply asked where an intake could be custom made so inexpensively, then provided my reasonings (accumulated costs) for buying vs building an intake when you suggested building one DIY style.
It all boils down to what someone is willing to pay and what they want things to look like when done. I Looked 8 months to find one (cast 4bbl intake on my Poly) for what I was willing to pay. I wanted something that would provide low/ mid end power since my car is driven on the street and looked like it came with the car. I doubt a fabricated intake would have been able to be built for the same cost ($280 including shipping), nor would it have fit under my hood. Cast'd manifolds also have attaching points for original components (throttle/ kickdown linkage, coil, A/C brackets, etc.). I know, Lokar makes cable setups, but that just adds to the costs...remember, our conversation was about keeping them down.
As for my tools and their use? Below is the latest work I've done with them. I know I'm biased, but I kinda like the results. I think I'll keep using my tools(including both welders), even if someone else could make better use of them...though for me it is just for enjoyment, not to make money.
Start with a piece of 'coal'
Turn it into a 'diamond'
Tools actually being used
I started with this
and ended with this
Now, maybe we should let 6t4polara get back to selling parts.
Is no longer available.
Nice work and a thick skin is needed by those around you here. You read it right. Adding the cost of learning to a possible project is a sad way to look at things.
If you bit hex about it, I'd have to ask is that same schooling cost added to everything you do from here on out or does I diminish with ever stick you burn, every spool of wire, every argon tank used or is that added cost as well.
To many people cry over the money they spend on the hobby to learn something. They'll just bitch and cry and then grumble over the pipers charge. Nothing like doing it yourself. If ya can't, all of you that can't, stop crying and learn or pay up.
You say you can weld, then practice with thin sheet metal and start thinking intake design. Use what is all ready out there as a guide.
If you complain abou material costs, trying 3 times, crap, pay the piper.
All the parts have been sold.
Thanks to all and For B Bodies only.
