Need ID of this item
AFB
3:53 AM
X
I would appreciate someone telling me what this fits?
I could not find a part number. Thanks for all the replies. The pic really helps.
Should be a part # under the gasket and I vote on a 68. But is a 4-dr or 2-dr? They are different. Couple of the studs are about 1/4" off between 2-dr and 4-dr. Same holds true for 68/70 Satellite and 68/70 Coronet.
Should be a part # under the gasket and I vote on a 68. But is a 4-dr or 2-dr? They are different. Couple of the studs are about 1/4" off between 2-dr and 4-dr. Same holds true for 68/9 Satellite and 68/70 Coronet.
Why on earth would they have done that? My guess is they are the same across the board in each model line.
I have no idea why. Tail lights are the same between the two. I learned this when I sold some Coronet extenions from a 4-dr to a guy and they would not fit his 2-dr. So did some research. That was a few years ago and I still can't figure out why they did this. Silly engineers
Found some part numbers:
2838355 LT BC
46430
2842721
What can I say? Gettin' old! :glasses10:
