Grabinov911
- 11:12 AM
- Jan 27, 2012
- Southern California
Yup. That was me at Spring Fling in SoCal negotiating with Dr. Diff for the new 489 case Eaton True-Trac 3.55 rear end for my '70 Roadrunner. I couldn't help myself, since that was one of the items on my list for the car, which had a 3.23 open rear end - which ain't great for handling or performance.
So I set about getting it installed this week. Axles came out with no problems at all - after a few minutes of "not getting it". The service manual says to use the hole in the axle flange to access the axle bearing hold-down bolts. IT'S THE BIGGER OF THE HOLES IN THE FLANGE! YOU SEE, THEY'RE NOT ALL THE SAME SIZE! While I was in there I decided to change out the bearings. the car has 50,000 miles and is 40 years old after all. Dr. Diff sold me the proper Green Bearings for the replacement. With all the debate about Green vs. Timken, I figured if they came from him, they were good enough for me. Read on in the service manual as it described the technique for beating the axle bearing holder and axle race into submission. Seriously? You want me to what? Beat on the holder with a chisel without nicking the axle? Split the carrier with a chisel? Grind off the bearing race to remove the rollers? I did one axle this way - most of it at least before I scared myself - worried about destroying the axle.
This is what's left when you do it the factory way:
Well That's about enough of that. This is why there are places called So and So's Axle and Driveline. Took them about half a day and voila, you get this:
Removed the old diff by loosening all of the hold down bolts and pushing up on the front of the case with a floor jack - just enough to split the case and drain the fluid into a drain pan. So proud of myself at this point - and wondering what was about to go wrong. Nothing's ever easy with this car. I removed all of the nuts and allowed the old diff to rest on the jack - still balanced by the studs in the axle. It felt so light - I told myself this must be because it's an open diff. The new one from Dr. Diff is so much heavier. Huh. whatever. Had my son (9 years old) pull the jack out. No problem, now I'll just slide it off the studs and onto the floor - 12 inches down. WHAM!
Well not exactly WHAM. That is the sound the diff would have made if it had landed on the cardboard on the floor. It didn't make that sound because the blow was softened by my (gloved) wrist. It actually sent a shock up my arm. I pulled my arm out expecting to see my wrist severed, but luckily it was just a bruise. Hurt like hell for a day or two though. Don't do that. Get someone to lower the diff ON the jack. Or just let it fall on the floor - it's coming out anyway. I had actually thought about all of this in advance and then failed to listen to my own advice. Does this ever happen to you?
So I waited two days for the swelling and bruising to subside and had my son help me lift the new diff into place with the jack. No problems. It is nice working on gears that are actually an inch or more across. A slight bump against the housing is not going to hurt that thing! And the studs allow it to slide on perfectly. This is my kind of install. fits in one direction only with no adjustment. I used a FelPro gasket with liberal amounts of Permatex to make sure it won't leak. Why? 1.) I HATE things that leak, and 2.) I am NEVER going to do this again by myself on my back, so if the diff is a bit stuck, someone with a lift will be dealing with it!
Beautiful.
The axles went right back in. No adjustment with the Green bearings, so just tighten 'em em up - with a little bit of Permatex on the gasket for good measure. the last thing I did was add new gear oil to my new diff. Cass (Dr. Diff) recommended 85/140 conventional, so I bought enough for the 4.4 quarts shown in the service manual. I started with the rear of the car up in the air, but only got about 2 quarts in before the oil was coming back out the fill hole. I can't lower the rear or I'd never get the oil in (with the car sitting on the ground), so I raised the front. This did two things for me. First, it allowed me to get another quart of oil into the diff before it started to drip out the filler. Second, it allowed me to drain about a quart of trans fluid out of the automatic trans housing - oh yeah, did I forget to mention that I had taken out the driveshaft to change the U-joints? LUCKILY I had placed a pan under the trans when I removed the driveshaft in the first place.
One strange outcome though: I was only able to get 3 quarts of gear oil into the diff even with the car level. The service manual says it should take 4.4 quarts. Anyone know why this would be? Is there a quart+ of oil that was still inside the axle housing even though I had the differential off? I didn't go to any effort to drain or dry it other than removing the differential. Anyone have an idea? How do I know FOR SURE that there is enough oil in there? I guess I need a lift...
Beautiful.
