71_Duster
Wanting to check and reset the hydraulic flat tappet lifter preload in my 440.
Checking the Hughes info that I have as it's all their stuff.
Cam is an HEH2832bl
Hughes racing lifters
and CNC 1.5:1 rocker shafts
Also running aluminum heads which I am unsure if this will effect where my preload should be?
Hughes says for street/strip preload is .015/.020 or 1/4 to 1/2 turn.
If I read correctly following the adjustment chart per cylinder and spin the pushrod until it has 0 play and won't easily spin then my 1/4 to half turn preload?
Cam is an HEH2832bl
