- 12:26 AM
- Apr 13, 2012
- Granite Bay CA
Thanks to all that responded in the other thread I started "Living with 10.8 compression of the street".
The calculated comp is actually closer to 10.73, but I realized it after starting the thread. I have received much help and have been asked questions that I cannot answer. One of which is the ROD LENGTH. I am unsure of how this affects the issue of detonation.
I just finished doing a compression check. Here are the results. All plugs out, throttle open, engine cold.
#1) 215 #2) 217
#3) 210 #4) 220
#5) 213 #6) 211 ** Pretty consistent numbers, huh?**
#7) 211 #8) 215
Seems pretty high, huh? When I first built the engine in 2004 I had a buddy help me degree the cam. He suggested that I advance it, so we set it to 4* advanced. THEN the cranking #s were all over 230.
So the threads and posts I have read say that most of the time, anything over 190 means pump premium will not be good enough. I already knew that, but now I have the numbers to prove it.
Seems like the advice I have been getting is starting to sink in. I'll need a bigger cam!
#1) 215 #2) 217
#3) 210 #4) 220
#7) 211 #8) 215
