- 1:40 PM
- Apr 13, 2012
- Granite Bay CA
Hello again.
I'm getting ready to check my pushrod length for the new rocker arm kit I bought from Mancini racing. As is often the case, it is now after hours and there is nobody there to answer the question. Also once again, there were NO instructions included. When are these guys going to realize that not everyone is a seasoned engine builder?
I understand the theory of checking length, but in this case, the tool I received has no measurements on it. It states that it is for 8.8 to 9.8 length. With it bottomed and tight, it measures 8 15/16ths from end to end, but this doesn't account for the recess in the top end where the ball of the rocker arm adjusting bolt fits in. It has a series of dashed lines on the fixed side and the side that screws out. I was able to spin it 22 rotations before it came out.
I'd add pictures but this site is different from FABO and I can't figure it out.
For the sake of discussion, is this the proper procedure?
Install rocker arm gear, torque to spec.
Adjust length tool to zero lash.
Set rocker arm nut to 1/4 to 1/2 turn tighter than zero lash.
Remove checking tool and measure total length.
Correct? It seems that the cup end could theoretically be more than a half sphere and skew the numbers a bit. It seems that a more accurate measurement would be from lifter plunger to the rounded tip of the rocker arm adjuster ball.
What is the DEAL, man!!!??
