Vacuum fitting for intake manifold
kevahoya
2:29 AM
Sacramento, CA
I need a replacement vacuum intake fitting for my 69 Charger with A/C. you can only buy the single port ones for the brake booster but mine has three. One for the headlights and the other for the Heater-A/C controls. Any help would be greatly appreciated
If my memory serves me correctly, on my 68 Charger the vacuum line goes from the intake to a three way port on the power brake booster. One port goes to the vacuum canister for the headlights. The other is blocked off but could possibly be used for a/c controls. Not home now but pm me & I can check for sure.
I checked and my brake booster does have a second port capped off but I'm pretty sure the 69 had that three way fitting on the intake as I had the original engine when I got it and it definitely looks 40+ years old. Either way I'd still need the smallest port for the A/C. I know I can come up with something but I'd rather have it looking original. Thanks so much for the help!!!
Any luck with this? I need the exact same set-up for my 68 charger with ac/headlights/power brakes
I had a couple of them, I can check if you are looking for one.
If they are in good shape yes. Please pm with pictures.
