Mr.SpeedFreak
Hey guys I'm looking at replacing my rear main seal, but I've had one of the Mancini Racing kits with the cnc machined retaining block on backorder for over 2 months now and at this point just want to cancel my order and use a generic seal with the stock retaining block.
The problem is, I was told if I get the generic seals that the kit should also come with two straight pieces of rubber to seal each outer side of the retaining block (total 4 piece kit). But every one I'm seeing has the two half circle seals and two "L" shaped right-angle seals like the attached picture. Is this correct or does anyone have a suggestion on a kit to use?
I was told the new kits just tell you to fill the outer edges with silicone which I figure would eventually leak, so that's what I'm trying to avoid. Thanks ahead of time :headbang:
